Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Question about ground wire.....
Author Thread: Question about ground wire.....
Username: Its_bacon12
Post Number: 9
ok my friend is a retard and he uses 8 guage to power his amp, but he uses something like a 20 awg speaker wire to ground it. its not like he's using much power, hes got 2 kicker comps and a kicker 150.1 or something like that so, and btw, his subs sound liek shiz so does he need an 8 awg ground cable for that amp to really kick it up a knotch?
Username: Cutlas
Post Number: 14
A bigger ground is always good, i have a 4 guage power wire and a 4 guage ground thats less than 3 feet long (prety big but i bought it all in a preformance wiring kit for $70 canadian)also check that theres no paint where the ground it and that theres a good connection
Username: Glasswolf
Post Number: 189
yup. use 8AWG to ground the amp to bare chassis metal. Bob's right on the money there.
It should make quite a difference.
So will properly setting his amplifier gains for those subs, and probably building a better speaker box depending on the one he uses now.
These are all just suggestions for improvement.
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Question about ground wire..... [ « Previous ] [ Next » ]
