Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Amps with capacitors
Author Thread: Amps with capacitors
i am hooking up 2 amps each with its own capacitor, do i put the capacitors before or after the distribution block?
Username: Glasswolf
Post Number: 152
you realize capacitors serve no real purpose, right?
that being said, you can place each capacitor just before the positive terminal of each amplifier's power connection, or you can combine the caps before the distro block so that each amp can use both capacitors as needed.
that's up to you.
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Amps with capacitors [ « Previous ] [ Next » ]
