Thread: Changing the seatbelt buzzer |
Bronze Member Username: Dean_k
Regina,
SK
Post Number: 18 Registered: Jun-04
| Posted on Wednesday, August 25, 2004 - 02:30 am: |
I own a 1994 Plymouth Sundance and I'm wondering if anyone has ever replaced the buzzers that sound to tell you your seatbelt is undone or you left your lights on I would rather have something that goes "ding ding ding", because the buzzer i have is ungodly annoying.. It reminds me of the "world's most annoying noise" off of dumb and dumber thanks for the help cheers |
NorthWest,
Michigan
Post Number: 4452 Registered: Dec-03
| Posted on Wednesday, August 25, 2004 - 01:38 pm: |
well that's the idea.. to annoy you into wearing your belts and turning off teh lights when you get out of the car! actually I just disconnect mine usually, but then I wire the headlights to a sensor to turn on and off when its dark on their own, so its not something I really need to be reminded about.
Regina,
SK
Post Number: 19 Registered: Jun-04
| Posted on Wednesday, August 25, 2004 - 03:21 pm: |
4-8 seconds of an annoying buzzer doesnt make anyone wear their seatbelt i always wear mine, but thats because id like to live if i ever got hit by someone |
