Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Amplifier Suggestions
Author Thread: Amplifier Suggestions
Username: Emoney2
Boyceville, Wisconsin
Post Number: 17
What Amp would you suggest for my MTX 6000 which push 250 rms and 500 peak a piece. What would be a quality amplifier for under $200?
Username: Davids2004
Houston, TX
Post Number: 651
Is it svc or dvc, 2-4-6 ohm.
Username: Emoney2
Post Number: 19
Ah 4 ohm....and what is dvc and svc?
Visitor#78
DVC = Dual Voice Coil
SVC = Single Voice Coil
You can tell by looking at the back of the sub.
It will either say DVC or you'll be able to tell by the 2 sets of terminals.
Username: Emoney2
Post Number: 23
Well there is only one set of terminals on my sub box....so.,.,.
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Amplifier Suggestions [ « Previous ] [ Next » ]
