Thread: 551X Turning Off. Please help |
New member Username: Ben_k
Post Number: 1 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 11:52 pm: |
i just finished hooking up my 4 channel Rockford Fosgate 551X into my 12" Type R. I bridged it to 2 channels and wired a channel per voice coil, it sounds great however the amp is getting encredibly hot and is turning itself off. how can i prevent this? do i need to wire it differently? is there another solution? any help is appreciated. |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 643 Registered: Jun-04
| Posted on Tuesday, August 24, 2004 - 12:23 am: |
Is your sub dvc or svc. 2 or 4 ohm. |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 475 Registered: Apr-04
| Posted on Tuesday, August 24, 2004 - 12:24 am: |
Rockford Amps are well known for getting hot (i have one). I would like to know how it is mounted and where in you car it is. It is best to mount you RF amp vertically. That will be best for cooling. I have had many problems with mounting RF amps horizontaly (flat). But you problem isnt wiring its cooling. Also if the amp is in a area that doesnt get air flow (from wind or what not) then it will cause problems. |
Post Number: 2 Registered: Aug-04
| Posted on Tuesday, August 24, 2004 - 12:30 am: |
its dvc. its just flat in the back of the station wagon on a board. now to try to help the cooling i put 4 3/4" blocks between the amp and the base board but i guess thats not enough |
Post Number: 3 Registered: Aug-04
| Posted on Tuesday, August 24, 2004 - 09:33 am: |
what can i do to help it cool so that it wont turn off? |
Bronze Member Username: Joe718
Post Number: 92 Registered: May-04
| Posted on Tuesday, August 24, 2004 - 11:43 am: |
are your coils 2 ohm or 4 ohm. if there 4 your straight if there 2 you cant wire them the way you have them. if there 4 ohm heres where you get creative. if you open a rockford amp there is alot of space inside to mount a fan. there like 7 dollars at radio shack or any computer store just get a small one. Wire it to you ground and remote turn on leads an you will be straight. you can even use the side of the ampmount on one each side, use one to pull air in and one to pull it out. |
Post Number: 4 Registered: Aug-04
| Posted on Tuesday, August 24, 2004 - 11:47 am: |
they are 4 ohm. ok thank you for all your help! if there are any other ideas dont hesitate to put them up! thanks again |
Tucson,
AZ
Post Number: 477 Registered: Apr-04
| Posted on Tuesday, August 24, 2004 - 12:50 pm: |
Putting those 3/4" block should help. That would give the amp air flow to both sides. The air flow in a station wagon should be sufficient. Is there any where you could mount it Vertically? That would help out the most. |
Post Number: 5 Registered: Aug-04
| Posted on Tuesday, August 24, 2004 - 12:58 pm: |
i just called the rockford fosgate technical support. they said that the 551X wasnt made to do what i am doing with it and there is no real way to help solve the problem. im just going to get an audiobahn 8002T and push 200rms to each voice coil. at least that has an intake system. any other suggestions on two channel amps? im putting the 551X on ebay |
Tucson,
AZ
Post Number: 478 Registered: Apr-04
| Posted on Tuesday, August 24, 2004 - 01:09 pm: |
Thats not what i would have done but its your loss. |
Post Number: 6 Registered: Aug-04
| Posted on Tuesday, August 24, 2004 - 01:17 pm: |
i havent done anything yet. what is your suggestion? |
Houston,
TX
Post Number: 653 Registered: Jun-04
| Posted on Tuesday, August 24, 2004 - 08:44 pm: |
Here is what I would do. That sub is 300 rms and with the dvc 4 ohm you can run it at 2 ohm. This amp will be your best bet and proably about the cheapest you will find. Ok I just checked and he doesnt have any for sale right now but give him a day or so and he will have some. The xtant A3001 will give you 300 rms at 2 ohms and a perfect match for your sub. Here is his list of stuff for sale on ebay. Keep checking it and he will have one of the amps I mentioned above for 65.00 shipped. Ive talked to alot of people who have bought from him and no problems. http://cgi6.ebay.com/ws/eBayISAPI.dll?ViewSellersOtherItems&userid=dependabledav id&completed=0&sort=3&since=-1 |
Tucson,
AZ
Post Number: 480 Registered: Apr-04
| Posted on Wednesday, August 25, 2004 - 01:23 am: |
Well i would work around the AMP you have now. I am almost positive that the problems you are having are because of ventalation, not wiring. If you could do some testing that would be good. Try mounting the amp verically to a board. Drive around for the same amount of time you did w/the horozontal way and see if it does it. If it does then we need to look into it but i am sure its the way its mounted. You have a great amp, i would work around it. And i certanly would never trade in a RF amp for Audiobahn anything. |
Post Number: 7 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 02:10 am: |
i did mount it vertically and the same thing happened. the song will play for about 25 seconds and then the amp just turns itself off. its really annoying. i am thinking about getting this amp for it, it will be cheap and easy Sony XM-2200GTX. what are your thoughts? |
Houston,
TX
Post Number: 659 Registered: Jun-04
| Posted on Wednesday, August 25, 2004 - 02:28 am: |
Its his wiring. He has a 2 channel amp bridged at 2 ohms and its only stable bridged at 4 ohms so yea its time for a new amp that is stable at 2 ohms. IMO the amp I mentioned above would be your best bet or a P3001,301M would work well also. |
Gold Member Username: Jonathan_f
GA
Post Number: 1293 Registered: May-04
| Posted on Wednesday, August 25, 2004 - 09:54 am: |
Go get a mono amp that will put out the recommended power at 2 ohms, generally the cheapest option as Class D amps are cheaper per watt. A JBL 300.1 is a cheap amp and very good, also optimized for a 2 ohm load. Very few 2 channel amps are stable to a 2 ohm bridge and will be the same as running a 1 ohm load on a channel, less headroom and worse sound quality, plus more current draw and more heat from the amp. |
Post Number: 8 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 03:19 pm: |
so, the amp is wired at 2 ohms... how? i swear that on it is capable at putting out 275w X 2 bridged at 4 ohms? is it worth trying to finda cooling fan? |
Tucson,
AZ
Post Number: 481 Registered: Apr-04
| Posted on Wednesday, August 25, 2004 - 06:03 pm: |
OK, now that you've tried that, then its your wiring. I will bet you alot of money that if you buy a Sony or Audiobahn amp you will have more problems than what you have now. I would try to buy some kind of RF AMP. You could make some good money off that 551X, so basically trade your 4 channel in for a mono amp. That would work best. Its not worth the cooling fan. |
Tucson,
AZ
Post Number: 482 Registered: Apr-04
| Posted on Wednesday, August 25, 2004 - 06:09 pm: |
Try this, then you could sell the other amp for as much or even more than you bought this one for. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64572&item=5716957395&rd= 1 Wait to buy it though. Lets get some more opinions about it first.
Post Number: 9 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 06:22 pm: |
do you think that an audiobahn 8000t mono would be good. i just called circuit city and they said that i needed 500-600 watts for the sub. |
Tucson,
AZ
Post Number: 484 Registered: Apr-04
| Posted on Wednesday, August 25, 2004 - 08:37 pm: |
Well i guess you could try it and see, i mean you could always return it. But never listen or take Circut City or Best Buy literally. Most to all those guys suggest you the worst option. |
ffffffffffffffffffff Unregistered guest |
| Posted on Monday, September 06, 2004 - 08:56 am: |
how do i wire a rockford fosgate 301m and a 15inch sub at 2 ohm? |
