Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > The unBRAKEable autolock.. anyone eve...
Author Thread: The unBRAKEable autolock.. anyone ever used it?
Username: Dean_k
Regina, SK
Post Number: 16
http://www.surftilyoudrop.com/unbrakeable-autolock-pro.htm
It's like the club, except instead of clamping on to the steering wheel, it provents the brake or clutch from being depressed, which makes sense, because it would take a LOT more work to cut thru the brake or clutch than a steering wheel (at you cant drive it if you cat the damn brake pedal off)
has anyone used it before? wouldnt having something holding down your brake make your brake light always be on?
any opinions on this product?
Username: Dean_k
Regina, SK
Post Number: 17
sorry, a better site is http://www.youcansave.com/lockp.asp
also i made a few typos, my bad, i just woke up ;)
jal
I have it and I like it. It doesn't hold your brake down, it lifts it up so that no one can press it down and take the car out of park. I store mine under the driver's seat and it installs in seconds
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > The unBRAKEable autolock.. anyone eve... [ « Previous ] [ Next » ]
