Thread: What sub amp to use with speakers? |
New member Username: Vipervail
Post Number: 1 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 01:08 am: |
i have two 10" 400watt max 200watt rms subs what wattage should i look for in an amp to push them properly and clearly |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 629 Registered: Jun-04
| Posted on Monday, August 23, 2004 - 02:53 am: |
Are your subs dvc or svc. 2 or 4 ohm then we can recommend an amp. Ported or sealed box. What subs do you have. |
Post Number: 2 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 03:00 am: |
svc 4ohm no box yet but looking for suggestions i can build anything i just need to know what material |
Houston,
TX
Post Number: 632 Registered: Jun-04
| Posted on Monday, August 23, 2004 - 03:24 am: |
I would look on ebay for an xtant A3001T. You can get it for 100.00 shipped. It will give each sub 150 rms and port those subs. What subs do you have? |
Post Number: 3 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 04:06 am: |
radio shack subs i picked up for 10 bucks each never been touched figured id give them a shot to at least mock up a future system |
