Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Xplod amp keeps going into protection...
Author Thread: Xplod amp keeps going into protection mode
Username: Rmikeandmelissa
Cabot, Arkansas
I have a Xplod 760 watt amp hooked up to two 12" Xplod subwoofers in an enclosed custom box. I think I may have hooked up the wiring wrong to the amp because when I turn it up, it shuts down. So, I bought thicker wires for the woofers and hooked it back up, but I can't turn the gain up much at all before it shuts down again. It sounds horrible now, with hardly any bass at all. Can anyone send me a wiring diagram showing how to hook it up, including hookup of my regular car speakers to it???
Username: Davids2004
Houston, TX
Post Number: 625
So you have an one sony amp hooked up to two sony subs and the amp keeps on shutting off. What amp and what subs do you have and then we can help ya out more. What is happening is you have your amp running at too low of an ohm load.
Username: Kaosr
play with the wiring. Hook A positve wire from one speaker and the negitive wire from the other to the amp bridged. then connect the free positive and negitive wires together and that will fool the amp to believe its one 8 ohm speaker and should hit good.
Cabot, Arkansas
Davids2004, it's a Xplod 760 watt amp and two 12" Xplod woofers.
Chace, I will try that tomorrow and see how it works out and let you know. Thanks
Houston, TX
Post Number: 630
Model #'s please on amp and subs.
Username: Koz1031
Monticello, In
United states
Post Number: 42
I thought sony subs were 4 Ohm.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Xplod amp keeps going into protection... [ « Previous ] [ Next » ]
