Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Should I go Parrellel or Series???
Author Thread: Should I go Parrellel or Series???
Hey, I have a Rockford Fosgate 800a2. It's an 800 watt 2 channel amp. I have a 1 farad RF capacitor, 2 12" JL audio w3v2 4 ohm subs, i just ordered a sealed box, and i also just ordered a wiring kit- SCOSCHE AKPA-41. It is a 800 Watt EFX 4 gauge single amp power and audio wiring kit.
It comes with 17 ft EFX-2 clear jacket, spiral shielded OFHC audio cable with frosted RCAs,
17 ft 4 ga. red power cable, 4 ft 8 ga. black ground cable, 17 ft blue remote turn on, AGU in-line fuse holder, and Terminals and instructions are included.
I've installed home audio systems, but never car stereo. I'm going to attempt the installation myself. Good idea? From what I hear it's pretty simple... and i have directions.
Is there anything else I need to buy?
I think I still have to buy a fuse. What kind of fuse should I buy?
And when I hook up my subs, I believe I need to run wires from the subs to a speaker terminal ports on the box. What kind of wires do I use for that?
Oh ya, important... Should I connect the subs in series or parellel? And what's the difference?
Thanks for the help!
Username: Davids2004
Houston, TX
Post Number: 631
Those subs should be dvc 4 ohm. Basically you will hook up the voice coils in series and then bridge the amp.
I would say an 80 amp fuse.
12 Gauge wire of any kind will be fine for the subs.
Username: Orldypc
12 gauge wire? You mean to run from the subs to the speaker terminal port on the box? but doesn't that defeat the purpose of using 4 gauge in the first place? And what is the sound difference between hooking it up in parrellel or series? Sorry, I don't know anything about sound systems.
Username: Orldypc
And where should I ground my amp? In the instructions it says 'no chasis grounding'
Username: Forcesofchaos
Post Number: 7
Here is a site that tells you everything you need to know from basics to advance stuff
walkthrough on how to install most components
http://www.caraudiohelp.com/
on the right side of screen tab area click the areas that you want to read about.
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Should I go Parrellel or Series??? [ « Previous ] [ Next » ]
