Thread: How do i instal this cap? |
New member Username: Audiobahn_man
Freakmont,
MI
Post Number: 6 Registered: Aug-04
| Posted on Sunday, August 22, 2004 - 02:23 pm: |
Hey i bought a digital audio cap yesterday, i read the instructions but im kinda confused, wil i have two + wires, one comming from the battery, and one leaving for the amp. another question is how do i charge it, it gave this littl light balb thing that has two short wires going from it but no idea how to charge. can i have a 4 gage wire going to the cap, and an 8 gage going to the amp from the cap? thankx |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 599 Registered: Jun-04
| Posted on Sunday, August 22, 2004 - 05:58 pm: |
Basically to charge it here is what you do. Take one side of that light bulb wire and touch it to the + side of the cap. Touch the other side to the power wire. Hold it there and the light should come on. Hold it there for about 30 seconds or until the light goes out and you should be set. And yes you can run 4 gauge to the cap and then 8 guage out but why not run 4 gauge out also unless you have a small amp. |
Freakmont,
MI
Post Number: 9 Registered: Aug-04
| Posted on Sunday, August 22, 2004 - 07:39 pm: |
Ok thankx thats what i thought |
