Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Why is amp getting hot
Author Thread: Why is amp getting hot
Username: Tripperdiv
Post Number: 16
i have 2 12" bostwick dragr subs and an 1100.1 bostwick amp going to each sub-both are wire to 1 ohm at the amps and 1 of the amps is hot while the other is cool to the touch,they both have their own power and ground wires they are not hooked together.any guess why this is happening and will this burn up the amp thats getting hot,.thanks
Username: Davids2004
Houston, TX
Post Number: 597
Do you have all settings the same on both amps.
Post Number: 17
i made sure of that and everything is set at the same levels on both
Houston, TX
Post Number: 600
Maybe one has more room around it to get rid of the heat and one doesnt. You have both subs wired the same.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Why is amp getting hot [ « Previous ] [ Next » ]
