Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Newbie amp wiring help
Author Thread: Newbie amp wiring help
Username: Nrclptcnsmniak
im wondering what the best way to wire my 1400 watt 2 channel amp: 250x2 rms watt @4//700x2 max watts@2//1400x1 bridged @4:::::: to my 2 subs: sony XS-L121P5. if anyone cud either explain or draw a picture in paint or something i would really appreciate it.
the amp is bridgable
i think they are single coil and the max rms is 350
the subs are 4 ohms
Username: Davids2004
Houston, TX
Post Number: 595
Wire each sub to its own channel.
Username: Audiobahn_man
Freakmont, MI
Post Number: 7
yea, go here i think this is what ya need
if you amp is 2 ch, wire each sub to each chanel like this
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Single+Voice+Coil+-+4+ohms&image.x=22&image.y=13
if i do that then wont my speakers be underpowered since they run at 350 rms and the amp only puts out 250 on each channel at 4 ohms?
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Newbie amp wiring help [ « Previous ] [ Next » ]
