Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Subwoofer Wiring
Author Thread: Subwoofer Wiring
Username: Tmf
Vicksburg, MI
United State...
If You have a DVC Subwoofer at 2 Ohms, You can wire it up so that it is 1 Ohm, or 4 Ohm. However, Would it be better to wire them in paralell, and get a 1 Ohm stable amplifier, or should I wire them in Series, and Get a 4 Ohm amplifier? What are the Pros and Cons?
Username: Tmf
Vicksburg, MI
United State...
Post Number: 11
Well, what I mean to say, is what are the Pros and Cons to Series and Paralell Wiring.
joe davola
well you get more power out of your amp at lower resistance levels. I dont now if there is anything elce.
Username: Joe718
Post Number: 90
some amps are stable at 1 ohms but if it isnt a very good amp you get distortion and alot more heat off of the amp than it woul be at 2 or 4 ohm. You will also pay alot more for a good 1 ohm stable amp compared to a 2 or a 4 ohm amp.
Username: Davids2004
Houston, TX
Post Number: 628
Well Class d hifonics amps are all stable down to 1 ohm and are pretty cheap. I would run it at 4 ohms and get a 2 channel amp.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Subwoofer Wiring [ « Previous ] [ Next » ]
