Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Help me im stumped
Author Thread: Help me im stumped
Username: Isuzu_shit_box
Malibu, Cali
Usa
hi i recently put in my recieiver wich ist very good and that is hooked to a equilier I have but the troublr im having is with the amp. Ok so it hooked it all up the rite way i think,the battery wire gos to the amp the rcas go to the amp and i have the remoe going to th amp and the ground is fine but i cant seem to figure out why the protect ligt gos to red.some one please help me!!
Username: Davids2004
Houston, TX
Post Number: 591
What subs and amp do you have.
Username: Tmf
Vicksburg, MI
United State...
Well, I the first thing I would do is double check to see if you have your fuse in your fuseholder, because if you have your remote wire hooked up, and do not have your battery hooked up, it can often turn your protect light on, and, of course, your amplifier will not turn on without being hooked up to the battery. If you do have your fuse in, I would get a test light, and see if your remote wire has power. Good Luck.
Malibu, Cali
Usa
yes my fuse is in but if my remote doents have power do i need a new deckor is there some way to fix this problem its really fustrating
Username: Koz1031
Monticello, In
United states
Post Number: 44
do you mean the remote for your h/u or the remote wire from the h/u?
Username: Koz1031
Monticello, In
United states
Post Number: 45
oops sorry i MISREAD LAST POST. You can also run the remote turn on for the amp from the fuse box. there is usually an empty assy. I just found the positive side and plugged it in there. (Note positive side of fuse is normally on the right hand side.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Help me im stumped [ « Previous ] [ Next » ]
