Thread: 95 mustang and no clue |
Unregistered guest |
| Posted on Saturday, August 21, 2004 - 12:46 am: |
here's the deal, i have a set of 12" titan subwoofers in a box in the trunk of my 95 mustang wired up to a cheap walmart amp (i know, i'll be gettin a new one) through a pioneer cd player. i got new, i thought decent, pioneer 6x9's for the front and back (4 speakers) i blew the tweeters in the rear 6x9's the front ones are fine. the subs aren't pushin but i figure a new amp will do the trick. i have 2 questions 1. could i use this walmart amp as a crossover for 2 rear speakers and set them on treble then install new speakers to replace the blown ones (which would make 2 speakers in rear and 2 set on trebble)?? 2. and if so or if not, wat do i need to make a decent system (cuz i've seen bigger fuse boxes, extra batteries, i don know wat they're for and i just don't know wat i need to do)? its somewhat of a tight budget but i just want a loud, thumpin system so i can save up, so please help me out and hook me up. all the system does now is looks good. i figure it should sound ok too. |
