Thread: Wiring Diagrams |
New member Username: Kmgar
Vista,
California
Post Number: 1 Registered: Aug-04
| Posted on Friday, August 20, 2004 - 10:38 pm: |
I am looking for a wiring diagram for a Sony CDX-CA705M. Sony doesn't have them on their website |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 617 Registered: Jun-04
| Posted on Sunday, August 22, 2004 - 11:59 pm: |
What do you mean. Like what the different color wires mean or what? |
Vista,
California
Post Number: 2 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 09:31 am: |
Exactly....What do all the wires and plugs on the back of the head unit go to? I think i figured the speaker wires...but i'm still not sure of all the others. |
Houston,
TX
Post Number: 662 Registered: Jun-04
| Posted on Wednesday, August 25, 2004 - 04:05 am: |
Black is ground Yellow is memory Red is 12 volt source Blue with white strip remote wire Orange illumantion wire hope that helps some. |
Unregistered guest |
| Posted on Monday, September 13, 2004 - 12:09 am: |
Alpine CDA-7841(Made in Japan) had problem with optical head but can`t find it.What optical head(similar) can be replace to my cd player unit. |
