Thread: What EQ/Crossover? (paging Glasswolf) |
New member Username: Coronach
Post Number: 5 Registered: Aug-04
| Posted on Friday, August 20, 2004 - 12:59 am: |
OK. I'm terribly new to all of this, so bear with me. What I have right now is this: HU: Nakamichi MB-75. Speakers: Infinity Kappa 5x7s Amp: MTX Thunder1004 (4-channel) Sub: RE8 Amp: MTX Thunder 251D (mono) (I can dig up stats on all of these, just tell me what info is needed) I want to pull all of this together properly, but I'm not entirely sure how. I know I want an EQ (I like the adjustment flexibility), but I dont know which one, or what features I need with this setup. Anyone have advice? Right now the only things installed are the HU and the Infinities. Thanks, Mike |
NorthWest,
Michigan
Post Number: 4414 Registered: Dec-03
| Posted on Sunday, August 22, 2004 - 06:34 pm: |
are you looking for an EQ to 'tune' the system once its together? or do you want something in-dash to monkey with as you feel the urge while listening? this will make a diference in the type of EQ I'd suggest
Unregistered guest |
| Posted on Tuesday, September 14, 2004 - 09:09 pm: |
Sorry about this question but i just have to no it. What is a EQ and what does it do |
Bronze Member Username: Whitebread
Post Number: 28 Registered: Oct-04
| Posted on Sunday, October 17, 2004 - 09:45 pm: |
An equalizer is a device that lets you adjust the gain (or volume) of a frequency or frequencies on teh music you are playing. There are two types, graphical and parametric. A graphical EQ already has set points at which you cna boost, anywhere from 1 band all the way to 30 (an eclipse model). A parametric lets you assign the number of bands, band width and amount of gain for each band. |
NorthWest,
Michigan
Post Number: 4825 Registered: Dec-03
| Posted on Monday, October 18, 2004 - 01:13 pm: |
from what ya said I'd go with a pre-amp/EQ setup that mounts in-dash. kicker has one, Orion's is/was the 300PSW (they sell on ebay now and then), zapco has one, audiocontrol does too.. these generally offer volume, fade, balance, and 3 to 6 bands of EQ adjustment, usually graphic or parametric. unless you feel the need for 11 separate bands, that'd be my suggestion.
