Thread: Whats wrong |
New member Username: Mu_forever
Post Number: 7 Registered: Jul-04
| Posted on Thursday, August 19, 2004 - 03:57 pm: |
i was trying out a new amp for my subs and at low volume they sounded good then when i turned it up, after about 30 sec the subs just stopped working completely. i looked at the amp and the protect light was not on so what caused this? btw i found out later they were running at the wrong ohms. they run at 2 when bridged but the amp runs at 4.(the guy told me wrong specs about the amp) |
New member Username: Particleman
So. jordan,
Ut
Us
Post Number: 6 Registered: Aug-04
| Posted on Thursday, August 19, 2004 - 04:16 pm: |
try trying a new ground connection |
New member Username: Tmf
Vicksburg,
MI
United State...
Post Number: 7 Registered: Aug-04
| Posted on Saturday, August 21, 2004 - 06:42 pm: |
Did you check the fuses yet? |
Post Number: 8 Registered: Jul-04
| Posted on Monday, August 23, 2004 - 01:58 am: |
yeah, i checked the ground and fuses and both were fine. i hooked them up back to my old amp and they hit but not near as hard. Thanks |
Silver Member Username: Soccer
Post Number: 293 Registered: Apr-04
| Posted on Monday, August 23, 2004 - 08:33 pm: |
How thick is your wiring? |
Post Number: 9 Registered: Jul-04
| Posted on Tuesday, August 24, 2004 - 11:00 am: |
im using 8 ga. power and ground wire and 12 ga. speaker wires. |
Bronze Member Username: Joe718
Post Number: 91 Registered: May-04
| Posted on Tuesday, August 24, 2004 - 11:30 am: |
chances are if the amp is not tunrning on at all no power and now no protect light, the amp is most likely gone |
Post Number: 10 Registered: Jul-04
| Posted on Tuesday, August 24, 2004 - 06:05 pm: |
Both amps work fine, its just that now my subs dont hit as hard before they suddenly stopped firing. |
Post Number: 299 Registered: Apr-04
| Posted on Tuesday, August 24, 2004 - 08:35 pm: |
You MUST make the amp's impedance match the sub's, or have you done it allready? |
Bronze Member Username: Mu_forever
Post Number: 11 Registered: Jul-04
| Posted on Thursday, August 26, 2004 - 07:09 pm: |
the subs are hooked up correctly |
