Home > Message Board > Car Audio > Head Units > Archive through March 16, 2004 > Pre-amp output
Author Thread: Pre-amp output
Username: Ukw10
Post Number: 7
What is Pre-amp output?? Could Someone explain to me. Do I need this to install amp for subs??
Username: Glasswolf
Post Number: 99
pre-amp outputs are RCA line connections that are used to connect between a head unit and external amplifiers.
you want at least one set of these on any radio you plan to use with an amplifier.
Username: Ukw10
Post Number: 11
Why does Head unit has different preamp outputs like Front, Rear and Sub
Username: Glasswolf
Post Number: 106
for multiple amplifier setups.
front speakers (channels), rear speakers, and subwoofers.
having separate channels allows you to have control over balance, fader, and sub output as well as crossover and EQ in better head units like Alpine or Eclipse.
Username: Ukw10
Post Number: 14
If you want to put amplifier for subwoofers but Head unit only has preamp output for front and rear, can i just connect RCA to fron or rear output??
Username: Glasswolf
Post Number: 133
yes. just be sure the amplifier has a built in low-pass crossover so that only low frequencies go to the amp, and then to the subs.
Home > Message Board > Car Audio > Head Units > Archive through March 16, 2004 > Pre-amp output [ « Previous ] [ Next » ]
