Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > About amp watts
Author Thread: About amp watts
is it ok if my amp has 150watt by 4 channels and my four speakers have 130 watts rms is that ok. is my amp too powerful? do i need to get a different amp? can i set my amp to put out less watts?
thank you
Username: Hydro
If 150x4 is the amp's RMS power then u might wanna turn ur gains down but u dont need a different amp
Username: Glasswolf
Post Number: 18
gains have no effect on an amplifier's power output, contrary to popular belief.
the gains simply match the line voltage to the input voltage for the amplifier.
never use gains as a volume or "power" control.
set them properly the first time.
as for 130 watt speakers on a 150W amp, that should be fine. it's close enough to spec.
If anyone wants links to sites regarding how to adjust amp gains, let me know.
could you give me a site explaining how to adjust gains?
Username: Glasswolf
Post Number: 30
sure
http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=34.topic
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > About amp watts [ « Previous ] [ Next » ]
