Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Need amp advice
Author Thread: Need amp advice
Downward-Facing Dog
I have an AudioBahn AB123Q enclosure. runs at 800 watts RMS and 1600 watts peak. what would be a good amp to purchase?
800 watts at what impedance?
What is your budget?
Downward-Facing Dog
im dumb so i do not know what impendance is, so no clue. this is my first venture into car audio.
as for budget, the cheaper...the better.
Downward-Facing Dog
oh, its at 4-ohm mono
ok the box is 4 Ohms mono?
that's going to be tricky to get that much power then.
try the JBL BP1200.1 for about $285
that'll put out 600WRMS at 4 Ohms, mono.
www.etronics.com sells this amp for a good price.
Hydro
HA HA HA HA HA HA Glasswolf are u a JBL AMp Salesman cuz it seems to me thats all u say lol is JBL 1200.1
Downward-Facing Dog
i was thinkin a Audiobahn a2150hcx...your thoughts on this particular amp?
DFD
any other advice?
Username: Glasswolf
nope, JBL is just the cheapest decent amplifier line around. that or cadence.
audiobahn is total crap IMO.
I don't sell anything anymore. I got out of sales years ago. I just install now, and I only install decent equipment.. heh
DFD
so...the jbl pushes 600 watts at 4 ohms mono. that will be sufficient for a setup that requires 800 watts rms?
Username: Glasswolf
Post Number: 17
the 1200.1 puts out about 700WRMS on a scope, at 4 aOhms, and the subs have a max RMS rating of 800 watts, so yes, the 1200.1 wqill drive them just fine with no worry of damage, as long as the amp gains are set properly.
DFD
alright, thanks a million
Username: Glasswolf
Post Number: 34
sorry about the typos there.
I was tired. I spent the last few days solid workin' on the system in the Jeep, and mounting some Hella 550 fog lamps before the snow gets any worse up here. It's chilly in the garage, even with heated floors, and I'm starting to think I'm getting too old to be crawling around engine compartments and under dashboards. haha
DFD
yeah, haha my system's goin in a 1991 ford aerostar haha
Username: Its_bacon12
rofl ford aerostar......mines in an 86 lincoln town car :-)
isnt that one of those funny-lookin vans?
DFD
lol you could say that...
Home > Message Board > Car Audio > Amplifiers > Archive through January 09, 2004 > Need amp advice [ « Previous ] [ Next » ]
