Thread: Is Sony good? for amps? |
New member Username: Trancein305
Hialeaj,
Fl
Usa
Post Number: 2 Registered: Aug-04
| Posted on Thursday, August 19, 2004 - 01:25 am: |
hey .i just bnought two awesome! 12" alpine type R's 1241D 4 Ohm subs. I was wondering if the sony amplifier will be a good amp to power my subs on the back of my 2001 Mustang? Sony XM-2252HX RMS Power Output @ 14.4V (High Current) 225W x 2 @ 4 Ohms 225W x 2 @ 2 Ohms 300W x 2 @ 2 Ohms 300W x 2 @ 1 Ohm 600W x 1 @ 4 Ohms (bridged mono) 600W x 1 @ 2 Ohms (bridged mono
Bronze Member Username: Sixstar
Post Number: 38 Registered: Aug-04
| Posted on Thursday, August 19, 2004 - 01:34 am: |
Sony is not very good, and it will make your subs sound worse. How much would you be willing to spend on an amp? |
Bronze Member Username: Joe718
Post Number: 89 Registered: May-04
| Posted on Thursday, August 19, 2004 - 02:00 am: |
not good at all |
Bronze Member Username: Koz1031
Monticello,
In
United states
Post Number: 30 Registered: Jul-04
| Posted on Thursday, August 19, 2004 - 06:12 am: |
you are gonna have to custom make the box for those 12's. Mustangs just weren't made to take a 12 in sub. Their trunk is big enuff, but the tail end configuration makes it imposible to get the box in there. The only way I found to do it was to go single boxes, or build the box in the trunk. 10's are a much better choice for that car, as the box will fit alot easier. Other than that everything is a breeze. Everything but the door panels snap in, and there are only 2 screws holding the door panels on. The back seat can be a bear to get out, but it will come out, and the driver side kick panel is a little tough. |
Monticello,
In
United states
Post Number: 31 Registered: Jul-04
| Posted on Thursday, August 19, 2004 - 06:14 am: |
Oh by the way stay away from SONY stuff. |
