Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Basics
Author Thread: Basics
how do u wire an amp??
Username: Audiobahn_man
Freakmont, MI
dude, go buy a wiring kit from walmart or something and fallow the directions, its pritty simple
Username: Davids2004
Houston, TX
Post Number: 564
Ok here you go.
Wire a power wire from the battery with a fuse within 12 inches of the battery and run that to the amp.
Remote wire will be hooked up to the back of the radio. Look for a blue wire with a white and hook up your remote wire to that and run it to the amp.
Next find a good piece of metal or the chasis of the car and ground your ground wire there and run it to the amp.
Also run your rcas from the back of the radio to the amp.
Then speaker wire from speakers to amp
Thats the jist of it.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Basics [ « Previous ] [ Next » ]
