Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Im a newbie
Author Thread: Im a newbie
Username: Mu_forever
im looking for a mono amp that does around 800 RMS at 2ohms. when im looking at the specs i see the ratings at 12.5 and 14.4 vdc. what does that mean and what is the difference between the two? thanks for the help
Username: Joe718
Post Number: 80
the mtx Thunder801D will give you about 800 rms @ 2 ohms basicy you get 14 volts when the car is running an 12 when it your just running off the battery but higher end amps that say they give more power at 14 volts are much better.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Im a newbie [ « Previous ] [ Next » ]
