Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Diagram for 2004 Jeep Grand Cherokee
Author Thread: Diagram for 2004 Jeep Grand Cherokee
can any help.I have an Autopage RS-850 with a DEI 455J door lock module and a DEI 556U by-pass module.Having problems with the door trigger and door locks,it locks and unlocks,but only unlocks the driver door.And I have a car starter,it works,but the BRAKE,ABS,AIR BAG light stays on.here is what I hooked up this is from the Autopage.STARTER OUTPUT=YELLOW//+12V=RED&PINK/BLACK //IGNITION OUTPUT=DK.BLUE//ACC.OUTPUT=RED&BLACK//. Do I need a IGNITION 2 OUTPUT and a SECOND ACC.OUTPUT. I did not jook these up, but it still starts,but the BRAKE,ABS,AIR BAG light stays on.need help
Username: Ps1k0
RI
sounds like you are missing an accessory or an ignition wire for the lights.
accorging to www.bulldogsecurity.com
you are going to need 2 relays in each door for the locks to work right
http://www.bulldogsecurity.com/wireing%20diagrams2.htm
If you post the site this way they don't have to search and the new way you will have to register after Sept. 1st...
Username: Ps1k0
Post Number: 9
yes, but you see i was preparing them for the sept 1st change ;)
actually, i've never seen that page b4.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Diagram for 2004 Jeep Grand Cherokee [ « Previous ] [ Next » ]
