Thread: Mid-Bass Speakers |
New member Username: Colin1
Post Number: 4 Registered: Aug-04
| Posted on Monday, August 16, 2004 - 08:55 pm: |
Im getting a pair of mid-bass speakers for my rear deck. I have people in my car a lot, so I want them to have some sound. BUT, I also want it to sound good for me (could even fade them out when no one is in the back). Should I get a good pair of them that take a lot a fair amount of power like some Image Dynamic CX's, or, since they are rear deck, and won't be played loudly anyway, should I look for something that takes only like 30-50 watts, like some Infinity Kappas or Focal 130CA's (are either of those good mid-bass drivers even?) Of course, it might be a little bit harder to find a good small amp to bridge and to feed such little power (to run them in mono). all 5.25 inchers btw (so I don't have to make a difference panel) |
Gold Member Username: Jonathan_f
GA
Post Number: 1182 Registered: May-04
| Posted on Tuesday, August 17, 2004 - 07:58 am: |
I'd just do a set of midbasses like the Image Dynamics, or Morel, Focal makes midbasses, also Adire Koda mids. They'll sound great if you use a bandpass crossover (around 150 hz-3k) and yes, I'd give them a small amplifier. If you already don't have an amp for components, just get a four channel, wire the midbasses in series and bridge the rear channel for a mono 8 ohm load. If your rear channel of the 4 channel has a HPF, set it to around 150 hz. |
