Thread: Running amp off stock hu |
New member Username: 95z71
Post Number: 1 Registered: Aug-04
| Posted on Monday, August 16, 2004 - 08:18 pm: |
got a 95 z71 chevy.. going to use a cheap amp at first with 2 12" kicker comps, i have the power from battery 8g wire with fuse and ground. Then going to run remote from stock hu. but here is my question the stock hu has no rca output, i remeber seeing some1, take speaker wire and hook it up to the stock right rear speaker wire and left rear speaker wire and hook it up to an rca output box! is this right or will it work???? |
Silver Member Username: Purplehase_bong
Bc
Post Number: 163 Registered: Apr-04
| Posted on Wednesday, August 25, 2004 - 02:26 pm: |
nope the amp has to have a hi level input(speaker wires from amp) |
Bronze Member Username: Topedgeonline
Montrose,
Colorado
United States
Post Number: 14 Registered: Sep-04
| Posted on Thursday, September 02, 2004 - 01:48 pm: |
Here is the part you need to wire an amp to a factory stereo: http://www.topedgeonline.com/detail.aspx?ID=8113 Very easy to install, just hook up the right and left speakers and this converts the signal to an rca level. |
