Thread: How is this amp? |
Bronze Member Username: Nalej85
Grand Prairie,
Tx
Post Number: 11 Registered: Aug-04
| Posted on Sunday, August 15, 2004 - 11:28 am: |
I have a Power Acoustik 2400 watt class d amp, is it worthy of anything?Any feedback would be appreciated. |
New member Username: Blindc1rca
Post Number: 7 Registered: Aug-04
| Posted on Sunday, August 15, 2004 - 12:58 pm: |
yea thats a good amp, at 75% its a little less efficient than one would like to see out of a class D amp but its still infinitely better than an a/b, especially if youre running it at a 1 ohm load. The amp is good, but only as good as what it is running (plus I hope you have a capacitor cause 1800w constant is a battery drain). So what kind of subs/speakers are you running with that? |
| Posted on Sunday, August 15, 2004 - 04:22 pm: |
u wont need a cap...what you will need is a bigger alt!!! what size fuse does the amp have??? i would bet $100 to a donut that power acoustik 2400w amp wont put out 1800 RMS. |
Grand Prairie,
Tx
Post Number: 12 Registered: Aug-04
| Posted on Sunday, August 15, 2004 - 06:58 pm: |
Im thinking of running one Kicker SoloBaric 15 inch or one JBL GTI 15 inch. Fuse is 30.Amp puts 1200 rms i believe. |
| Posted on Sunday, August 15, 2004 - 08:43 pm: |
well...if the fuse is a 30A the the amp will only make 300watts RMS of clean power!!! ANYTHING that it supposedly make over 300watts WILL BE CLIPPED!!! you could run a solo 15 or a JBL...but i would get a better amp...look at a JBL bp600.1 or 1200.1, they will put out what they say and then some! |
Bronze Member Username: Pkilla21
Post Number: 39 Registered: Jun-04
| Posted on Sunday, August 15, 2004 - 11:22 pm: |
Yea Jon, switch the amps up because Power Acoustics isn't really good and will never give you the most out of Solo. |
Grand Prairie,
Tx
Post Number: 13 Registered: Aug-04
| Posted on Monday, August 16, 2004 - 03:10 pm: |
It's a 30 amp fuse, but there are 4 fuses connected to the side of the amp.So would that be 1200 watts instead?I'm really new to this, thanks for the feedback. |
