Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Amp Output Problem
Author Thread: Amp Output Problem
Thomas Trickelstien
I am getting no signal from 2 of my four channel amp
one left and one right
Was fine ntill today I had not touched it prior to this happening I tested it with different speakers, cables and such and no signal
Any thoughts
Thanks Tommy
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 26
sounds like the front or rear channel on your amp is bad. if you havent, swap the rcas around just to make sure.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Amp Output Problem [ « Previous ] [ Next » ]
