Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Simple question!
Author Thread: Simple question!
Username: Pdivvy5
CT
United States
Post Number: 54
I was wondering what would be a good amp for 2 12 JL Audio W0's. I have no brand preference, and it would be good if i could keep the price around $150...
Username: Davids2004
Houston, TX
Post Number: 519
are they 4 or 8 ohm.
Username: Caraudiofng
Houston, TX
Post Number: 42
Those are 125wRMS subs.
I'll make 2 suggestions for 4ohm or 8ohm
If they are are the 4ohm version you could go with:
A.) XTANT A3001 - Excellant Amp for the money. Great reviews. $135.77 shipped
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573&item=5715044762&rd= 1
B.)Hifonics Brutus BX500D - this is also a good deal $152 shipped
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5714648902&rd= 1
If they are the 8ohm version, try these:
A.)JBL GTO301.1 $155 shipped
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5714003857&rd= 1
B.)HIFONICS NX750D $181 Shipped
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5714518115&rd= 1
Was hard to find much in your $150 budget, but these should work. (even though the last one went over $30)
My srong suggestion would be wait until you have a little more money like $200 even. Then you could get like a JBL 600.1
FNG
Username: Pdivvy5
CT
United States
Post Number: 56
I was actually looking at the 600.1 awhile ago, and i liked it a lot. I did not buy it because i thought it would be too much power for my subs. If it is not too much power, then i will definetly buy that amp. Do you think it is too much?
Username: Symplestiles
Stockton, CA
Usa
Post Number: 48
if you run it at a 4ohm load it will put out 150watts per sub which would work fine.
Home > Message Board > Car Audio > Amplifiers > Archive through August 23, 2004 > Simple question! [ « Previous ] [ Next » ]
