Thread: Would this alt. be enough???My stock 1 burned out!!!HELP!!! |
| Posted on Saturday, August 14, 2004 - 01:39 pm: |
ok...i had a 100A stock alt. and it burned out teh other day, so i'm stuck w/ no truck for a few days till i can get an alt!!! i am runnin a JBL 600.1 and i know i need a higher output alt... here are three that i am lookin at: 130A http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7915064752&ca tegory=33573 140A http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7915064778&ca tegory=33573 and a 180A http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7915064966&ca tegory=33573 all i have is one jbl600.1, what amp would be best for me???I NEED ONE FAST!!!HELP!!! |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 520 Registered: Jun-04
| Posted on Saturday, August 14, 2004 - 03:24 pm: |
The 130 one should be fine. I had a bd500 which was 600 rms and upgraded to a yellow top. So if your only gonna run that amp the 130 should be fine. |
Gold Member Username: Jonathan_f
GA
Post Number: 1138 Registered: May-04
| Posted on Sunday, August 15, 2004 - 01:36 am: |
What was your stock alternator rated at? That JBL will draw around 60 amps or a little more at full draw, if you have an alternator with that much or more reserve after taking account of the accessories of the vehicle, you'll be fine. |
GA
Post Number: 1140 Registered: May-04
| Posted on Sunday, August 15, 2004 - 01:41 am: |
Oops, didn't see that it was 100A, sorry. It really depends on how many accessories the vehicle has to run, does it have a lot of electrical accessories?(alarm, power everything, a lot of computer control, etc.) I personally would get a 180 amp to have headroom for the alternator, this will strain it much less. |
HELPmePLEASE Unregistered guest |
| Posted on Sunday, August 15, 2004 - 08:43 pm: |
the only thing electrical in my truck that isnt stock is my HU and amp...i was wondering if the 130A or the 130A would be enough, it says it would give 85A at idle and my stock 100A one only gave bout 60A at idle, would the 130A do??? or do you still think i should go w/ the 180A?...i need to order as soon as i can!!! |
Houston,
TX
Post Number: 530 Registered: Jun-04
| Posted on Sunday, August 15, 2004 - 10:34 pm: |
If your going with a higher output alternator then also upgrade your battery too. Now that I look at the prices you might as well go with the 180 not much of a price difference. This will allow you to upgrade your door speakers and all and put a nice decent amp on those also. |
