Thread: Testing Amp with Multimeter |
Vincenzio Unregistered guest |
| Posted on Saturday, August 14, 2004 - 02:51 am: |
I have a multi meter and I was wondering what current I test for coming out of my amp? AC DC Amps Volts Ohms I have no idea Thanks for any help |
Bronze Member Username: Fryguy
Barrington Passage,
Nova Scotia
Post Number: 50 Registered: Jun-04
| Posted on Saturday, August 14, 2004 - 09:01 pm: |
depends on what you are trying to measure. want to find the power output? total power the amp uses? or if all channels are working? channel polarity? |
| Posted on Saturday, August 14, 2004 - 11:08 pm: |
Thanks for responding, I am trying to test each channel individually to make sure they are all putting out the same power Thanks |
Barrington Passage,
Nova Scotia
Post Number: 59 Registered: Jun-04
| Posted on Sunday, August 15, 2004 - 01:50 am: |
This is the only true way to test. Remember that power equals volts by amps. so you will need a non-inductive test load (like a high wattage power resistor) and a true RMS digital VOM. A true RMS amp meter. A constant test signal will be required like a 1khz tone at 0db on a cd. (If you dont have a audio test cd i have a ISO i can link you to if needed). Then all you need to do is hook up the resistor to the amp output like a normal speaker but with the amp meter in seres with it. then play the tone and turn the amp up, read the voltage across the load resistor and keep turning it up untill the voltage reaches the max. read the max voltage and the current write it down. turn off equipment. multiply voltage by current to get the power output rating. |
Barrington Passage,
Nova Scotia
Post Number: 61 Registered: Jun-04
| Posted on Sunday, August 15, 2004 - 02:03 am: |
Audio is a AC (but the frequancy changes) so you need a AC amp meter and volt meter. True RMS gear is recommended to get a real reading of true power. note: some true RMS meters are only calabrated to read true RMS at 60hz! You'll get a fairly close reading though. |
| Posted on Sunday, August 15, 2004 - 02:21 am: |
Thanks for the imput I'll tr that out I have a fairly sophisticated Digi Multimeter It has more functions than I know how to use Thanks again Vincenzio |
Barrington Passage,
Nova Scotia
Post Number: 63 Registered: Jun-04
| Posted on Sunday, August 15, 2004 - 02:32 am: |
you think you have a bad amp or just measuring the power to your speakers? |
| Posted on Sunday, August 15, 2004 - 12:40 pm: |
bad amp |
