Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004
  Thread Last Poster Posts Pages Last Post
New or used amps?ryan c.2004-08-09  18:31 ET
Bigg Problem!!! Need Some HelpMike Loudon2004-08-08  23:30 ET
Amp for 12" kicker vr?AL2004-08-08  00:47 ET
For Sale: 2 jl 12w7's.....jl 1000/1 must selladam sss2004-08-03  18:31 ET
Is this amp compatible with these subs?ryan carter10 2004-08-03  13:48 ET
New system..need amp adviceAndrew Fox10 2004-08-03  01:59 ET
My bass comes out of my subs but also my front and rear speakersJoseph2004-08-02  19:22 ET
Briding a 4 channel to subbrad mcintee2004-08-02  16:54 ET
How much amp do i need??jimmy carpenter2004-08-02  15:38 ET
Will a 700s work with 2 adire audio shivasblare holz2004-08-02  14:56 ET
Need good 1k watt monoblock class d ampGrizzly2004-08-02  13:15 ET
2 Amps 2 Subs 1 Set of 6*9'sRob Lay2004-08-02  08:43 ET
What is best amp for...Anonymous2004-08-02  02:17 ET
Tweeking the jl audio 500/1?Jonathan2004-08-02  01:14 ET
System problem..need expert advicehelpmeout2004-08-01  20:38 ET
Think this item on ebay is good?GlassWolf2004-08-01  16:09 ET
Amp neededGlassWolf2004-08-01  15:53 ET
AlternatorGlassWolf2004-08-01  15:34 ET
Amp won't work rightjason Howard2004-08-01  01:24 ET
Amp problemsAnonymous2004-07-31  19:55 ET
My amp just went out can some one help....Brandon Spicer2004-07-31  19:45 ET
Anyone can help meGlassWolf2004-07-31  12:26 ET
GlassWolf please confirm !GlassWolf2004-07-30  13:20 ET
Question about ampGlassWolf2004-07-30  13:15 ET
I need help please!!!!!its_bacon122004-07-30  11:47 ET
My Amp Drains All ThE Power From My Battery What Should I Do?its_bacon122004-07-30  11:44 ET
12w7....Jonathan2004-07-30  08:28 ET
Which amp should i go with?brian walker2004-07-30  05:01 ET
I need help to connect amp in blazerEvan2004-07-30  03:43 ET
Ground Wire....Joseph2004-07-30  02:34 ET
Amp Questionmare wojcik2004-07-29  18:21 ET
General Amp Question about OhmsGlassWolf2004-07-29  17:53 ET
8 ohm subGlassWolf2004-07-29  17:49 ET
Help with wiring a 55 ChevySasarai12 2004-07-29  03:35 ET
Can't eliminate noise's from SpeakersJonathan2004-07-29  01:50 ET
Need help with amp/sub setup - Alpine Type SBryanB2004-07-29  00:24 ET
1997 Chevy SuburbanWilliam Reed2004-07-28  23:27 ET
Help me choose the best amp out of these 6 !!!!HELP !!!GlassWolf10 2004-07-28  21:51 ET
Amp QuestionGreg Profitt2004-07-28  20:03 ET
Plz do me a favorjojomunky2004-07-28  17:43 ET
Car amp questionAnonymous2004-07-28  17:31 ET
Titanium 3.1 ohm ?inprogress2004-07-28  16:59 ET
Understanding dual voice coilssgw35611 2004-07-28  16:43 ET
Im the amplifier godron kozma2004-07-28  12:28 ET
Diagramsron kozma2004-07-28  12:22 ET
JL 250/1 vs Alpine MRD-M301SteveK13 2004-07-28  12:10 ET
Which amp for two 12' alpine type r'ssinister minister11 2004-07-28  06:32 ET
Pioneer GM-X862 2-Channel 760 Watts Car Ampdavids20042004-07-28  04:46 ET
What amp for 12" visonikdavids200413 2004-07-28  01:43 ET
Coustic Ampjeremie boop2004-07-27  23:53 ET
Will this work?its_bacon122004-07-27  23:41 ET
Amp for ecplise subs?davids20042004-07-27  22:40 ET
Amp troubles: on light flickersAnonymous10 2004-07-27  21:36 ET
Car alternatorGlassWolf2004-07-27  20:39 ET
Please Help me make my final decision on my amp!!! David Waddle2004-07-27  20:28 ET
DEI 1100 D, where can i get one ?cody john miller2004-07-27  19:30 ET
No soundjoao ferreira2004-07-27  19:19 ET
Ground John Smith12 2004-07-27  18:52 ET
More speakers needed or overkill?Grmncrsnbr2004-07-27  15:39 ET
2 mtx thunder 6000 subs, which amp?new guy12 2004-07-27  15:12 ET
Cadence!!! Any thoughts!!!GlassWolf2004-07-27  15:07 ET
Remember Marathon subs?GlassWolf2004-07-27  13:51 ET
1000 watt amp with capacitor?????GlassWolf2004-07-27  13:20 ET
Boat stereo setup help(very challenging)Grizzly13 2004-07-27  11:27 ET
Finally made a decision... now how about the ampChris Brown20 2004-07-26  19:21 ET
Difference between amps?davids20042004-07-26  02:47 ET
Best amp for kenwood w3009 12'sdavids20042004-07-26  02:02 ET
Best system setup for 2 solo-baric L7sdavids20042004-07-26  00:44 ET
Understanding ohms / wiring subsdavids20042004-07-25  23:49 ET
New Amp....projectbass2004-07-25  23:19 ET
Amp Problems....projectbass2004-07-25  23:11 ET
Kenwood, Xtant, or JBL?Andrew10 2004-07-25  22:57 ET
Worth keeping or no?jeremie boop2004-07-25  22:42 ET
3-ohm loads and good mathGlassWolf10 2004-07-25  22:30 ET
Would a JBL GTO601.1 power a Rockford 10" p3 well?Joseph2004-07-25  21:40 ET
Are the JL Slash Amps Really that good ?davids20042004-07-25  21:32 ET
I need help finding an ampdavids20042004-07-25  20:51 ET
2 dvc 2 ohm subs @ 4ohmJayJ2004-07-25  20:45 ET
Amp PROBLEM: when car is started, amp flickers on/offjake koska2004-07-25  18:54 ET
Best amplifier to use for 2 solo-baric L7sChris Pansler2004-07-25  18:25 ET
A quick question (i hope a quick answer)curtis P2004-07-25  17:11 ET
Are soundstream amps good amps?GlassWolf2004-07-25  17:01 ET
Ohms an amp will run at?GlassWolf2004-07-25  12:12 ET
Ohm hookup to ampGlassWolf2004-07-25  12:07 ET
Is 2 ohm or 4ohm better?GlassWolf2004-07-25  11:51 ET
Directed amps any good?JayJ2004-07-25  06:17 ET
Sound problemken moua2004-07-24  17:51 ET
Arc or Memphis ??GlassWolf13 2004-07-24  17:09 ET
Trying to properly tune my amp, HELP!GlassWolf2004-07-24  17:06 ET
JBL 1200.1 GOOD ENOUGH?marshall white2004-07-24  14:39 ET
Amp Problems....GlassWolf2004-07-24  11:29 ET
Need help with Alpine amp.....GlassWolf2004-07-24  11:23 ET
Amp TroubleGlassWolf2004-07-24  00:11 ET
This Legacy sucks help meGlassWolf2004-07-24  00:07 ET
Sound quality helpGlassWolf2004-07-23  23:53 ET
Parallel and Series wiring?Anonymous2004-07-23  23:25 ET
Shiva ampAnonymous2004-07-23  21:15 ET
Amplifier sound problemsjoao ferreira2004-07-23  18:55 ET
This Legacy sucks help methislegacysucks2004-07-23  18:33 ET
Good deal, or too good to be true?Pat Lorenz2004-07-23  12:56 ET
Closed Closed: New threads not accepted on this page
Home > Message Board > Car Audio > Amplifiers > Archive through August 03, 2004 [ « Previous ] [ Next » ]
