Thread: Speaker Box |
| Posted on Wednesday, August 11, 2004 - 03:50 pm: |
I have a pair of kicker 6.5" DX60's that I need to mount in a box. I know they are designed for free air but I can't mount them in their stock location so I was wondering what the right sort of approach would be for a box i.e. sealed or ported and what sort of rough volume. Thanks |
Silver Member Username: Mattl
Bolingbrook,
Illinois
Post Number: 381 Registered: Jun-04
| Posted on Wednesday, August 11, 2004 - 04:39 pm: |
Sealed, and you should be able to get the cu.ft. info from Kicker. -Matt |
| Posted on Wednesday, August 11, 2004 - 05:22 pm: |
kicker is quite useless in that department, thanks though. I will try taking a look at what other companies recomend for their entry level 6.5" |
Bolingbrook,
Illinois
Post Number: 386 Registered: Jun-04
| Posted on Friday, August 13, 2004 - 08:25 am: |
Well, it took me a 20-second phone call to find out .3 cu.ft. -Matt |
