Thread: HiFonics reliability and performance. Jon, wolf? |
Silver Member Username: Jamtochristian
Williamsport,
Pennsylvania
USA of course!
Post Number: 160 Registered: Mar-04
| Posted on Wednesday, August 11, 2004 - 03:20 pm: |
I am looking to get into some different amplifiers as I have slightly modified the setup of my stereo, and I was thinking of a ZX4000, and 2 BX500D amplifiers. The ZX4000 will be powering my Perfect 6.1s, whereas the BX500D will be powering my each one Infinity Perfect sub(10"). My question is regarding the overall performance of the amplifers, and their actual reliablity. Ie... are they descent buys? |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 494 Registered: Jun-04
| Posted on Wednesday, August 11, 2004 - 08:21 pm: |
IMO the guys you have asked will proably say they arent that great but everything ive heard about them are good. The put out rated power and run efficent and are a good bang for the buy. These are my opinions from what ive heard. |
Gold Member Username: Jonathan_f
GA
Post Number: 1095 Registered: May-04
| Posted on Thursday, August 12, 2004 - 08:21 am: |
They're good for the price range. Same reason as Davids, they most likely will be very reliable and do what they're supposed to do according to specs. |
| Posted on Monday, August 16, 2004 - 01:39 am: |
I was looking at the Hifonics Brutus,instead of a JL amp,that would be powering a 13w7. Or should I just stick with JL Amp? |
