Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through August 23, 2004 > Quick question about compnents...
Author Thread: Quick question about compnents...
Username: Pdivvy5
CT
United States
Post Number: 44
Hi, im totally oblivious about comps. I was wondering if you HAVE to buy anything like kickpanels or anything special to install or have component speakers in my/your car (95 Ford Taurus). I dont know a whole lot about comps and was wondering if you guys could fill me in on what exactly they are. I looked on other threads from previous months and i couldnt find anything. So what i am trying to ask is are they like regular speakers where you just can install them in your door where your stock speakers are? I know you have to mount the tweeters or whatever, but how do you do that? Do you need a kit or something? Thanks.
Username: Mattl
Bolingbrook, Illinois
Post Number: 378
Installing the midrange portion of a component set is simply replacing the factory speaker. Although there will be a crossover "box" that splits the signal for the midrange driver and the tweeter.
The tweeter is mounted in a separate location (where exactly depends on which set you get) and usually requires a 1" hole saw to get a good flush mount. Depending on the mount type, you may use a 1" steel ring behind the hole to ensure a solid/tight fit.
That's about it.
-Matt
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through August 23, 2004 > Quick question about compnents... [ « Previous ] [ Next » ]
