Thread: Setting UP a Hifonics ZX4000 to an Infinity Kappa Perfect 6.1 |
Silver Member Username: Maxkilla
Malta
Post Number: 103 Registered: Jan-04
| Posted on Tuesday, August 10, 2004 - 03:18 pm: |
I wish to know what frequencies must i set up and if i must use HF or Full frequency range .... I won't my system to be Loud and with good quality... 10x |
Gold Member Username: Jonathan_f
GA
Post Number: 1069 Registered: May-04
| Posted on Tuesday, August 10, 2004 - 03:38 pm: |
You'll need to use the HPF, set it around 75-80 hz. Those Perfects will need to break in for a little while, so don't drive them too hard, set the gains correctly and keep it at half volume or under for the first 20-40 hours. At first the tweeters will seem strong b/c the woofer hasn't broken in, just a warning, you may want to cut them down on the crossover. I'm guessing you know how to set the gains. |
Malta
Post Number: 106 Registered: Jan-04
| Posted on Tuesday, August 10, 2004 - 08:51 pm: |
I set the crossovers to -3dbs is that right ? they are still a little bright but i guess i'll let them break in... What about the gains --- this amplifier doesn't have a gain setting on it as my boss pd-4000... how come ? |
Silver Member Username: Mattl
Bolingbrook,
Illinois
Post Number: 364 Registered: Jun-04
| Posted on Wednesday, August 11, 2004 - 06:43 am: |
-3dB is right. It'll sound better once the surround gets more pliable -- then you can turn off the HPF. Also note that there are some "break-in" CDs that run an hour of low/mid tones to speed up the process of loosening the woofer. DO NOT play it loudly -- it just needs to flex, not break. Not all amps have gains. -Matt |
