Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through August 23, 2004 > Are these good components?
Author Thread: Are these good components?
Username: Pdivvy5
CT
United States
Post Number: 34
I was lookin at these on ebay and heard that Focals are pretty good speakers. I was wondering if you could help me out and tell me if these would be good for my 95 Ford Taurus. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32819&item=5714566140&rd= 1 Now, if i buy these, i think my rear speakers (6x8) are blown. What would be some good spekers for the back? Also, do i need an amplifier?
Username: Jonathan_f
GA
Post Number: 1064
Don't worry about rear speakers, you don't need them. Those Focals are pretty good, but I'd look for a pair of Infinity Kappa Perfects for the price range, you can find them around the same price on Ebay and they're a better set of components.
Username: Pdivvy5
CT
United States
Post Number: 40
Even though my speakers are blown and sound like sh*t?
Username: Pdivvy5
CT
United States
Post Number: 41
Do these look good? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32819&item=5714563607&rd= 1. Also, do i need an amp?
GA
Post Number: 1067
Yeah, those components are good, also look at the Kappa Perfects. I meant to totally disconnect the rear speakers, you won't miss them. Oval speakers have increased distortion, uneven stress points, cone flex issues, etc. that degrades the sound quality. Rear speakers are also unnecessary. When is the last time you went to a concert with the music coming from behind you? Some people use midbasses as rear fill, I'd recommend 5.25 or 6.5" midbasses for the rear if anything, but they're not needed, as the front speakers will reflect off the rear of the car as it is. Rear speakers will pull the front soundstage to the back, meaning for you that the clarity and imaging of the music won't be what it could be without rear speakers.
Username: Pdivvy5
CT
United States
Post Number: 42
Thanks a lot Jon, you really helped me out i appreciate it. I have been looking at the Kappa Perfects, and i just dont have the money. Im sure the Kappa 60.5's will do nicley. Thanks again
Username: Pdivvy5
CT
United States
Post Number: 43
Would you be able to reccomend an amp for them? I dont have a preference or anything...kinda cheap would be good, maybe around $100. Thanks
GA
Post Number: 1073
JBL P180.2. Should be under 100 on ebay.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through August 23, 2004 > Are these good components? [ « Previous ] [ Next » ]
