Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > What amp to buy (help!)
Author Thread: What amp to buy (help!)
Username: Daven
Post Number: 15
Im about to get a adire tempest 15", its going to be in a sealed enclosure, its going to be mounted over the tire well. My question is, what amp should I use to push it? I have about a 200$ range, and the amp needs to have high imput.
Thanks,
Daven
Username: Daven
Post Number: 16
bump
Username: Davids2004
Houston, TX
Post Number: 478
What is the rms wattage on that sub and are they dvc or svc. 2-4-6 ohm and then I can help ya.
Username: Daven
Post Number: 17
dvc 750W total, and im guessing 6 ohm, but im not too sure. http://www.adireaudio.com/ theres the sight if anyone wants to confirm this.
Username: Daven
Post Number: 18
by looking at this though, i think its 4ohm
http://www.adireaudio.com/Files/TempestWhitePaper.pdf
Username: Jayj
Louisiana
Post Number: 407
If it is a 4 ohm DVC sub you can try a JBL600.1. Wire the sub down to 2 ohms.
Username: Koz1031
Monticello, In
United states
Post Number: 18
I believe its an 8 ohm
you can get it in 4 ohm for a meer $300.0you might want to read earlier posts, seems the shiva and brahma are better choices in the adire audio line.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > What amp to buy (help!) [ « Previous ] [ Next » ]
