Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Tired of looking for a box
Author Thread: Tired of looking for a box
OK some one please find me a quality sub box thats...
SEALED
Dual 12" cutouts
1.00 cu ft per side
or
PORTED
Dual 12" cutouts
1.80 cu per side
tuned to 32hz
im asking a little much but im tired of surfing and finding NOTHING:.(
Username: Jamtochristian
Williamsport, Pennsylvania
USA of course!
Post Number: 156
Descent boxes aren't that hard to build, why don't you just build one yourself, you'll save a ton of money, and often you can build a better one than you may buy. However if you're not the best with power tools, or a clutz, i don't recommend this, nor will i be held liable for you cutting an apendage off.
I think sounddomain.com has quite a few boxes and like a box search engine on their site. Expect to pay at least 150 for it though. You can build one yourself for about 45-50.
Sheet of 4'x8' 3/4" MDF, 26 dollars.
Liquid Nails, 2 dollars.
Speaker Wire terminal mount, 7 dollars.
Speaker wire, 12 dollars.
Silicone for sealing, 3 dollars.
Box of Screws, 7 dollars.
Total - About 57 bucks.
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Tired of looking for a box [ « Previous ] [ Next » ]
