Thread: Power Acoustik A1800DB.... |
Bronze Member Username: Fordtaurusbass
Iowa
United States
Post Number: 13 Registered: Jul-04
| Posted on Monday, August 09, 2004 - 06:28 pm: |
I have a 15" adire brahma that I just bought and I was just wondering if this would be a good amp to power it. It runs at 1400W rms at 1 ohm, and the sub is 1 ohm stable. Here is a link: http://www.etronics.com/product.asp?icatid=305&stk_code=powa1800db&svbname=309, also what would be the best type of box to put this sub into to get the most spl out of it. |
Gold Member Username: Jonathan_f
GA
Post Number: 1049 Registered: May-04
| Posted on Monday, August 09, 2004 - 09:15 pm: |
I wouldn't even touch that amp for the money, poorly made and overrated. You don't need that much power for a Brahma, you'll see that by reading the owners manual. For a Brahma 15" for SPL, a 4.0 cu ft box (net) tuned to 35 hz would hit very hard. Adire lists specs for the box. Anyway, you won't need but 600W, 800 at the most, to get that sub to full excursion. 600 will most likely do it with that big ported box. I'd advise you to run the sub on a 4 ohm load rather than a 1 ohm, the amp will have more headroom and sound better, and less heat issues. A 2 channel bridged for the power you want or a mono amp putting out 600-800 RMS would be perfect. |
