Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Battery post...soda?
Author Thread: Battery post...soda?
is pouring pepsi on the battery post a good way of cleaning of the excess stuff around it? Should I wipe the pepsi off or let it dry, or what? please help?
Username: Jonathan_f
GA
Post Number: 1032
It works pretty well, pour it on, let it sit for a second, scrub the terminal if needed, dry the post. You can put petroleum jelly (like Vasoline) or the specially made post jelly to prevent acid corrosion from happening again.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Battery post...soda? [ « Previous ] [ Next » ]
