Thread: How can i bridge my Sony Xplod XM 222MK2 |
New member Username: Slaben
Post Number: 1 Registered: Aug-04
| Posted on Monday, August 09, 2004 - 04:22 am: |
Iv'e got a crap 2 channel 222 watt max sony xplod amp, for my crap 200 watt max sub, I know these both are crap but they suit eachother and it's all i could afford at the time, but anyway, i dont have the manual for the amp and im not sure how to bridge it, can anyone tell me how? thanks |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 468 Registered: Jun-04
| Posted on Monday, August 09, 2004 - 04:42 am: |
If the sub is svc 4 ohm then you can. If so then run the positive of the sub to the positive of channel 1 and then run the negative of the sub to channel 2 and then that will be bridged. |
Post Number: 2 Registered: Aug-04
| Posted on Monday, August 09, 2004 - 07:15 am: |
i know it's four ohm, what does svc mean? and what do u do to the other two terminals on the amp? join them up, or just leave them? thanks |
Bronze Member Username: Ffxdevilarms
Post Number: 59 Registered: Jul-04
| Posted on Monday, August 09, 2004 - 01:03 pm: |
SVC stands for single voice coil. |
Houston,
TX
Post Number: 473 Registered: Jun-04
| Posted on Monday, August 09, 2004 - 08:18 pm: |
You will just leave them open and they wont be used. |
i hate xplod Unregistered guest |
| Posted on Tuesday, August 10, 2004 - 01:41 am: |
you know what i would do with ur sony system, i would throw it out. there is no point in dealing with bottom of the line equipment |
