Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > How would you attach an amp to the fa...
Author Thread: How would you attach an amp to the factory deck in toyota camry 01?
hello people can anyone give me some information on how would i attach an amp to my factory stereo in toyota camry 2001?
hmmmm
post if still have question
hmmmm
ok..first of all need to know how much watts is the amp..and how many channels..cause if the amp has heavy watts the factory speakers wont be able to handle and wont get good sound either..post your amp details and the speakers that u will be attaching with it. As far as the head unit goes...u need to find a a blue turn on wire or antenna wire behind your factory stereo and attach that to the "remote" slot of the amp. u need to attach a wire going from the car's battery to the amp power. this two things are common but need speaker info to attach speakers.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > How would you attach an amp to the fa... [ « Previous ] [ Next » ]
