Thread: Audiobahn AW1200Q 12" |
New member Username: Invain
Post Number: 7 Registered: Aug-04
| Posted on Saturday, August 07, 2004 - 09:52 am: |
I need help picking the right box. I don't care if everybody here thinks audiobahn is crap, I'm just a kid and I don't want to spend all my money buying $400 subs. Anyways, I need to know what kind of box I should use for the sub. Which box will get more out of the sub, and what size should it be? |
Silver Member Username: Sploosh56
Post Number: 331 Registered: May-04
| Posted on Saturday, August 07, 2004 - 01:54 pm: |
put it in a 3.0 cuft slot ported box tuned to 35 hz. i'm sure you know Audiobahn is crap with no SQ but in proprly built vented enclosure these will slam. http://www.carstereo.com/help/Articles.cfm http://www.bcae1.com/ With the site above on the right hand side scroll down until you see Basic Enclosure Calculations. click on that. Hope this helps.
| Posted on Saturday, August 07, 2004 - 02:50 pm: |
omfg, im looking at the Ads by Google on the side right now and 4/5 ads are Audiobahn adds... |
Post Number: 8 Registered: Aug-04
| Posted on Saturday, August 07, 2004 - 04:01 pm: |
thanks wahl |
Post Number: 9 Registered: Aug-04
| Posted on Saturday, August 07, 2004 - 04:18 pm: |
anybody else agree with wahl, or should I do something different, I really don't know much about boxes, and I want to make sure I get the right thing. |
Post Number: 333 Registered: May-04
| Posted on Sunday, August 08, 2004 - 12:34 am: |
If you really want to run that Audiobahn then make that box. It is the only way that it will sound somewhat decent. The SQ will be crap but it will pound. Check out the original snail shell. http://www.powered4sound.com/ |
