Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > I need wiring help!!!
Author Thread: I need wiring help!!!
Username: Invain
I have a sub that has dual 4 ohm voice coils. I want to wire it to a 2 channel amp, that bridges into 4 ohms. How do I do it, I'm kinda new to this stuff.
Username: Sixstar
Post Number: 23
Well, is the amp stable at 1 ohm? If not, then you can't bridge it and get the 2 ohm load you would need for that sub.
There is a good chance the amp can put out a good enough load at 4 ohms into each channel, and then wire each voice coil to one channel.
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > I need wiring help!!! [ « Previous ] [ Next » ]
