Thread: Remote start proble, |
| Posted on Friday, August 06, 2004 - 08:39 pm: |
the remote start part of my impulse security system that i hooked up to my 01 grand prix is giving me probles. it will start when i push the start button, but most of the time it will shut off after being started. i believe it is my factory alarm messing it up, but i cant tell if the factory system is off. need help badly |
New member Username: Ps1k0
Post Number: 5 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 01:10 am: |
sounds like it isin't getting a good tach reading. |
Bronze Member Username: Zacdavis~
Post Number: 90 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 03:09 am: |
01 grand prix, = PASSLOCK ||, you did bypass it, right?, sometimes they mess up, try directed's 555u they learn the code routine in seconds |
