Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Dual 4 ohm sub wired down to 2 ohms? ...
Author Thread: Dual 4 ohm sub wired down to 2 ohms? what was that guy talking about?
Username: Invain
In another thread a guy said that since my audiobahn is dual 4 ohm voice coils it is wired down to 2 ohms, or something like that. I'm kinda new to car audio, do I need an amp that bridges into 4 ohms for the sub, or do I want to run 2 ohms to it?
Username: Sixstar
Post Number: 22
No, its the way you wire it. Go here:
http://www.crutchfieldadvisor.com/S-sd5WvEbuLoj/learningcenter/car/subwoofers_wi ring.html?subs=1&impedance=DVC4x2
You want to wire the sub like the first diagram, and that will show the amp a 2 ohm load. If the rating on the sub is 500 watts RMS, then you need an amp that gives 500 watts into 2 ohms.
Username: Invain
By the way, how would I wire a dual voice coil sub to an amp, with the amp bridged?
Home > Message Board > Car Audio > Amplifiers > Archive through August 13, 2004 > Dual 4 ohm sub wired down to 2 ohms? ... [ « Previous ] [ Next » ]
