Thread: Battery post...soda? |
| Posted on Friday, August 06, 2004 - 03:34 am: |
is pouring pepsi on the battery post a good way of cleaning of the excess stuff around it? Should I wipe the pepsi off or let it dry, or what? please help? |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 447 Registered: Apr-04
| Posted on Saturday, August 07, 2004 - 12:36 am: |
I dont know about battery terminals, i know that using it to clean off crome is good. |
Silver Member Username: Jamtochristian
Williamsport,
Pennsylvania
USA of course!
Post Number: 149 Registered: Mar-04
| Posted on Monday, August 09, 2004 - 01:52 pm: |
I've never heard about pepsi doing that, but its funny cause I'm actually drinking pepsi as I type this, kinda disturbing thinking that stuff is a nice stripping agent for battery corrosion crud. At any rate, its probably best if you wipe it off when your done, or I've actually used sand paper to clean them up for mine. If your looking for more immediate results. If you leave the pepsi on, it'll continue to erode your stuff(thats bad).
Bronze Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 50 Registered: Jun-04
| Posted on Monday, August 23, 2004 - 11:58 am: |
I DON'T KNOW ABOUT PEPSI, BUT COKE WILL TAKE HYDRALIC FLUID OUT OF CLOTHING. |
NorthWest,
Michigan
Post Number: 4417 Registered: Dec-03
| Posted on Monday, August 23, 2004 - 02:04 pm: |
yes some coca-cola will clean the acid off of battery terminals. old trick. works well, but you want to rinse it off afterward to get the sticky stuff off from the sugar.
Bronze Member Username: Malby7
Post Number: 86 Registered: May-04
| Posted on Monday, August 23, 2004 - 03:53 pm: |
I'm going to stop drinking coke as of now! |
NorthWest,
Michigan
Post Number: 4433 Registered: Dec-03
| Posted on Tuesday, August 24, 2004 - 12:52 pm: |
your own stomach acid is a lot stronger than anything coke comes close to. better stop eating, too!
Unregistered guest |
| Posted on Tuesday, August 24, 2004 - 09:27 pm: |
This stuff about cleaning battery posts has been most helpful. If my stomach acid is stronger then how about throwing up on the battery. |
NorthWest,
Michigan
Post Number: 4443 Registered: Dec-03
| Posted on Tuesday, August 24, 2004 - 10:13 pm: |
yeah. I think you should try that.
