Thread: Kappa perfect tweeter locations? |
New member Username: Beek
Post Number: 8 Registered: Jun-04
| Posted on Thursday, August 05, 2004 - 06:29 pm: |
Just purchased a set of infinity kappa perfect components. Ive decided to mount the woofers in the o.e door locations. But where is the ideal position to mount the tweeters? And what is the best angle to direct them? Ive heard many different opinions: 1)Direct to the ear 2)Directly to the opposite persons ear 3)Up towards the rear view mirror Or any other ideas? Bear in mind it is quite a small car. (Opel Corsa) Very popular over here in England for young modders Thanks guys.... |
Silver Member Username: Jonathan_f
GA
Post Number: 960 Registered: May-04
| Posted on Friday, August 06, 2004 - 09:46 am: |
Close to the woofer in the door (below 5 inches preferably) angled up toward the center of the car works very well for Kappa Perfects. This will still have great detail, and allow the woofer and tweeter to blend vocals together better. |
Post Number: 9 Registered: Jun-04
| Posted on Sunday, August 08, 2004 - 06:23 am: |
Okay thanks jonathan. I didnt really have enough room in the door so i actually mounted them in the kick panel next to it, seems to sound very crisp and clear there Im now experiencing a strange kind of sudden sqheel noise as i turn the volume up pretty high. Is this what you guys call "clipping" ? What causes this? The amp im using is: 75w rms x 4 @ 4ohms. I know the kappa's are rated 100 rms. Is this what is causing the problem? Because i previously read a thread with u and Matt Lavalee having a big depate about underpowering the kappa perfects?
Bronze Member Username: Ffxdevilarms
Post Number: 43 Registered: Jul-04
| Posted on Sunday, August 08, 2004 - 05:23 pm: |
from what i have read, i think that the kick panel is where infinity recommends they are put. |
GA
Post Number: 998 Registered: May-04
| Posted on Sunday, August 08, 2004 - 05:28 pm: |
Is it a consistent squeal, or one that only happens when a strong tweeter signal is given? It very well could be clipping or distortion, but hard to say by the description. |
Bronze Member Username: Beek
Post Number: 11 Registered: Jun-04
| Posted on Sunday, August 08, 2004 - 05:37 pm: |
Its only when the volume is up high and hitting hard notes. I have the gains right down on the amp so im not even getting that much volume at all, just this strange noise. |
